Anyone have this problem (VSA/Emissions lights)
2 weeks ago I was driving around shopping when all of a sudden my VSA and Emissions lights came on. I stopped the car, turned it off and waited a few. Turned it back on and the VSA light went away but the "check emissions light" stayed on.
I called my dealership and they said to re-tighten the gas cap and then drive around for a bit. I did that and it went away after a few hours. Just to be safe I took it to the dealership and they said it was fine. Now tonight I have the exact same problem and it's really pissing me off. I live in one of the 2 retarded states (Oregon) that won't let me pump my own gas. I guess I have to get out every time I fill up and tighten the cap.
Has anyone else had this problem?
Missin my TSX =(
well... the gas-men arent completely to blame... the cap on the rdx does not say turn to 3 clicks... most cars say that... it does on my dads civic n my old tsx...
Might not be the gas cap -- I had the exact same problem. The first time I took it in, they couldn't find anything (probably thought it was gas cap also). Second time, they figured it out. My invoice says they "had to replace actuator to vtech". Haven't had the problem since.
Oh and if your fuel cap was loose you should get the "Check Fuel Cap" or "Tighten Fuel Cap" message on the MID.
The actuator brix mentioned is the VTC actuator if you want to mention that to your dealer. Again, not sure how this would affect the VSA system, but who knows what is tied together in the PCM these days.
Got Boost?Rdx/Base/CGP
well what the f**k did u did to your RDX!! goshhh me i take care of my rdxx so much lol maybe is those gas pump men fuc*ed your RDX lol
me i onlyhave the" low pressure tire"lights on bcuz i had to flat at the rear
edit: Thanks SASAir I'll mention that to them as well. Hopefully this will fix whatever is going on because I have no other problems with the car. I still love it, though!
Update: I finally was able to take the RDX in today. I told them what I read from here and they pretty much brushed me off saying it could be anything.
4 hours later I get a call "oh the VTC actuator failed a couple of times but the engineers don't want to replace anything at this time so we performed a system update. Call us if it starts acting up and we'll replace it."
same problem
I had the same thing happen to me today! i am annoyed but see that other people have experienced the same problem...i probably wont be able to get my car serviced for a couple of days b/c of the holidays...hope i will be okay driving my car around?? very frustrating...otherwise, i have been happy with the car...
Check emission system message?
With just less than 6000 miles on the vehicle, I got the "Check Emission System" message on the multi-information display. The malfunction indicator lamp also turned on.
Besides this message, I also got these message:
1) Vehicle Stability assist: 83 which further says there is possible something wrong with VSA and traction control system (TCS)
2) All-Wheel drive: 77
3) Throttle system: P1684
Sounds like I am having the same problem being described here. In the situations described on this thread, it seems the engineers replaced the VTC actuator though some what reluctantly. VTC actuator sounds like an important piece. Does it mean the vehicle does not have Vehicle Traction Control if VTC actuator is malfunctioning?
Some RDXs have had battery problems like these:
https://acurazine.com/forums/showthread.php?t=733
This might be a simple place to start from.
Dealer informed me that they need to replace the "Throttle Body" part. They were reluctant to give any more details. Not sure how faulty the part was, as the RDX was running just fine. Besides the malfunction messages, there wasn't anything perceptibly wrong with it.
If anyone happens to have a better understanding of the problem, please feel free to reply.
Now the vehicle will be with the dealer for 4 days while they get the part and replace it. They gave me a loaner, but it is still a hassle, and am a bit unhappy about the whole thing, more so considering the RDX has barely 6k miles on it.
2007 RDX Silver/Base
I got the same issue, Check engine light and VSA warning light is on. It happened after I made a stop for coffee, while stopped to wait for traffic to pass by, I felt a bit shaking, coming from the engine. When I looked at the RPM meter, it was going up-and-down between 2000 and 1500 RPM and the above two warning lights are on.
The car can still be driven at that point, and since I was so close to my office (less than 1/2 mile), I decide to continue to drive back to my office before I turn off the engine. During this time, the car is like lots of power (even better than S mode).
After arrived in office, before I turned off the engine, I double check the RPM during IDLE, it was still around 1300RPM although it is steady. Turned it off for 10sec, then turned it back on, everything goes back to normal. VSA light was gone, but Check engine light was still on. RPM went back to normal state. I knew this has nothing to do with loosen GAS cap at all.
Call up my dealer, they asked the same thing.. Did u tighten your GAS cap?
Anyway, I brought the car into the dealership and they did a diagnostic check. They came back with a diagnostic code: P1009 - VTC system stuck in advance mode.
It sure is related to the VTC system, but is it related to the VTC actuator, it cannot be confirmed yet.
My mileage is at around 6000 miles. Wonder if the VTC has some design fault....
that sounds exactly to what i had mentioned in an earlier post.
it seems to be better now..ie. the light does not come on anymore (fingers crossed)...it appeared to be a bit of a run around to get it fixed. i directed my acura dealership to this site to tell them what i thought the problem was.
what did your dealer do to fix the problem?
got the same problem today apparently. Mom and dad took the rdx out so I can't see it but they called and told me the Check Emission and VSA indicator is on....
Lucky for me the car is going into the dealership for startup issues (weak battery im guessing) and loud pop on cold starts this will be on the list too.
I told them to tighten the gas cap once the stop and park.
all indicators are gone after topping my gas tank off with sunoco 94 (which I always use) I did notice there was a bit of white residue where the gas cap screws in so I wiped it off and wiped the gas cap down and turned it 3-4 times, get in, start the car and error is gone.
Will it still be stored? I want them to check it and let me know what the code was just to make sure it was fuel system related.
argh its back (actually this is the third time now).
I'm not pumping gas, the car has to go in for some dash trim replacement this week sometime gonna ask them to look at the CEL and figure it out.
08 RDX Tech Silver/Ebony
I would suggest all of you that had the 77 and 299 warning codes to check with your service departments again.
My RDX ate its catalytic converter.
https://acurazine.com/forums/showthread.php?t=2326
Sorry to rekindle an old thread.
I have just had the same problem listed above.
After leaving the car for 2 weeks in a garage, upon re-starting, the VSA, Check Emissions, and check AWD warning lights all went on and stayed on. I had trouble with acceleration as well.
Took it to the dealer. FIrst reply: rodents chewed your wiring. Wrong. No rodents. No signs of rodents.
Second reply, well the batteries on these cars cant handle sitting for 2 weeks - it's just an electrical fault. Wrong - I had a fine start - not a slow start. And why would the lights still be on the next morning?
Third reply: what kid of oil are you using? You must be using bad oil. Wrong - I always use Mobil 1. Always. I watch the local oil change guys do it themselves.
Final answer - after they bothered to hook the car up to diagnostics -
The spool valve assembly is bad and they have to fly one in from SoCal Acura Techline to replace.The engine is not getting oil at high pressures.
Has anyone ever heard of this issue? The threads I have read here for similar issues have always been catalytic converter, or fuel cap - never the spool valve assembly.
The Emissons and VSA lights came on today on our 2008 RDX. I have a universal trouble code reader and found P1009 in the ECU. Seems to act up worse when the engine is real hot and it's been 100 degrees here the last couple of days. Had the Tighten Gas Cap message last week (we did but it was already tight) and haven't seen it come back on. I guess it's back to the dealer. Car only has 1200 miles on it. Not a good start.
stumo
stumo
haole kama'a-ina
P-1009...Variable Valve Timing Control (VTC) Advance Malfunction.
Step 1. Clear the DTC and see if it comes back. If not, system OK.
If it comes back:
2. Check the VTC strainer for clogging.
3. Test the VTC oil control soleniod valve.
4. Inspect/replace the VTC actuator.
If it comes back:
Thecrazytrains (09-17-2013)
Thanks for the info 737 Jock. Took it do the dealer yesterday and they did step 1 and nothing else. They were no where near as knowledgeable as yourself. Will see what happens but have a feeling the light will be back on.
Thanks again,
stumo
Thanks again,
stumo
If it comes back:
If it comes back:
Thanking all in advance.
haole kama'a-ina
The strainer and solenoid valve are located on the top right corner of the cylinder head and easy to access. See this diagram:
http://estore.honda.com/acura/parts/view-acura-parts-catalog-detail.asp?m=2012-rdx-5-base-2wd-5at&sn=&b=E++1010&dl=
The VTC strainer is item 9.
The VTC oil control solenoid valve is item 6.
The VTC actuator is part of the intake cam shaft and requires major engine disassembly.
For me, the question is why would the VTC strainer clog? I mean, there is an engine oil filter, and the screen is likely more coarse than an oil filter. So, just what is clogging the strainer?
I can understand the VTC solenoid failing, as it is an electrical device.
Yeah, hope never to have a failure of the VTC actuator.
Code P1009 Check Emissions/VSA System
I got this same code and warning light earlier this year. The warning lights would come and go throughout the year. Mostly towards the end of the oil life. I would change the oil then it would be fine for a while.
So, now that I have my radiator is out I was thinking about doing something to fix it. With all my research I have learned about cleaning the vtc solenoid valve and the vtc strainer.
I too am curious about why they would become clogged. Does it have something more to do about the viscosity rather than particles??
Should I just clean the strainer or should I go all out and check the solenoid too?
Or could it be something completely different?
... The warning lights would come and go throughout the year. Mostly towards the end of the oil life. I would change the oil then it would be fine for a while.
... With all my research I have learned about cleaning the vtc solenoid valve and the vtc strainer.
I too am curious about why they would become clogged. Does it have something more to do about the viscosity rather than particles?? ...
So, if you drive lots of short trips, and allow the vehicle to sit for a week at a time, that will create sludge, and block the VTC strainer, which I assume is the reason it is there.
Shortly after buying my used 2011 RDX base w/23000 miles on it.... Got a warning to check fuel cap. We'll I knew this was not the issue since I am a geek that reads owner manuals and this is ingrained. This progressed to emission warning with the engine VSA. took it to Acura dealer.
Informed of suspected rodent damage to a plastic corregated shield that sits on top of fuel tank and is part of the whole fuel tank assemblage kit. Hole very small but is letting enough emission through to trip a sensor. Svc advisor said it did not affect engine performance or fuel mileage, but if would have to replace entire fuel tank to make this issue go away....for $1200.00. I asked why couldn't it just be caulked with silicone or something if nothing was actually wrong with the tank itself. I asked a local repair shop about this. They said I could buy the tank assy myself and have an independent shop install, but it had to be a shop that could smoke test it. I suspect the used car dealer I bought this from reset the computer to hide the issue. Hate to waste money if there is an repair alternative. This warning indicator and VSA light drives us crazy.
Say what? and do you know which is the actual part suspected with damage? is it a separate part from the tank, or part of the tank? sorry, I did not quite understand your comment about being part of the assemblage (sp). Would you have to drop the tank to get to the suspected hole. Silicone seems like it would work, although I would use the sensor safe stuff.
Had both lights simultaneously come up on my Acura TSX'09, 60K miles, one year out of warranty. Well, actually it happened half a year ago. Took it to few mechanics, the first one just referred me to Acura dealership, the second one suggested to change the oil (I admit I was putting different oil there - sometimes synthetic, other times semi-synthetic) and see if it fixes the problem before we proceed with more involved things - well it didn't. Given that he charged me about $700 for changing front rotors and pads, honestly I'm a bit hesitant to come back for more involved procedures
The car feels underpowered now, it used to accelerate way better. Also, it started eating oil - I only did 1.5K since last change and the "check oil level" indicator just came up.
Stopped at the AutoZone and that's what the computer showed:
83-1 ABS
Engine Control Module (ECM) / Powertrain Control Module (PCM)
61-1 ABS
Battery Voltage Malfunction
CURRENT
Should I bite the bullet and go to the dealership? I've obviously been trying to avoid that, as I don't support their shady business practices. Any ideas?
83-1 ABS
61-1 ABS
CURRENT
Go to the dealer and get a diagnostic and quote for parts. If you don't like the price, talk them down, most dealership do not want to lose customers.
cycdaniel
12-17-2019 10:58 AM
brandnewcolony
09-12-2015 10:39 AM
HeloDown
09-08-2015 06:51 PM
