Acura ServiceNews *Updated for Aug 09*
I'm only posting the dates that cover the RDX. Anything before that you can find in the TL or RL sections. Or just change the date in the link. First two number are the year, the third and fourth numbers are the month. If you want Honda bulletins, you can change the B in the link to A...
B061200.PDF means B=Acura, 06=2006, 12=December, 00 stays the same
If you know of a new one that comes out and it hasn't been posted yet, PM me and I will update....
2009
August TPMS, Power Window Reset
July Broken Valve stems, Tire Sealant, XM cuts out
June Nothing RDX Specific
May Nothing RDX Specific
April Nothing RDX Specific
March DTC P0325 Knock Sensor
February Homelink, Power Mirrors
January SRS DTCs 32-xx and 31-xx Are Strictly About the Side Airbags
2008
December Nothing RDX Specific
November Nothing RDX Specific
October Nothing RDX Specific
September Tailgate Outer Handle Not Working,
August No Communication Between HDS and VSA Modulator-Control Unit
July Excessive Parasitic Draw? Check If the B-CAN System Is Awake
June AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied, DTC P2422
April Can't Turn VSA Off?
March VSA Indicator On after repair, MIL with aftermarket intake, HFL 5 of 5
February Poor Audio Quality, HFL 4 of 5
January HFL 3 of 5
2007
December HFL 2 of 5
November TPMS Info, Metallic Window Tint, SRS DTC, Nav Info, Interior Lights stay on, Security System, HFL 1 of 5
September Window regulator reset
August VSA troubleshooting, Running Fuel Tank Dry
July MAF Sensor, Window Tint, TPMS
June Engine block coolant separator
May HFL Locked, No sound or data from XM
April Parasitic current draw, cutting roof moldings
March Roof rack covers, DST, outside temp logic
February AT solenoid, Homelink
January Dead Audio Unit, Side Moulding Install Tips
2006
December - Nothing RDX specific
November - roof rack weight limits, front door courtesy light lens falling off, nav map matching, software update to fix brake system problem, TPMS info
October - AC fan noise cycling frequently, satin finish chrome and water spots, AcuraLink communication setup
September - nothing RDX specific
August - right power mirror problem on early VINs, software update to improve shift quality, engine won't start/immobilizer blinks
July - New RDX uses Mobile 1
2009
2008
January HFL 3 of 5
2007
December HFL 2 of 5
2006
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
sockr1
10-01-2015 01:31 AM
asahrts
09-04-2015 05:55 PM
