| Welcome to Acurazine.com! |
Thread Tools |
#1 | |||||
haole kama'a-ina
Oil Filter -- Honda vs Mobil 1
| Sponsored Links | ||
#2 |
'07 Carbon Pearl Tech
I guess I'll be taking a different filter for my oil changes from now on.
Thanks! |
#3 |
Does it mean that Mobil 1 is good to last two oil changes? I think manual says to change oil filter every other oil change. If this is the case, it might be better to use Mobil 1 filter.
#4 |
737 Jock, what is the Mobil 1 part number? Who handles them in the US?
#5 |
737, can you please analyze Wix filter for the RDX as well. It is what I use and form reviews on BITOG its quite good design.
Thanks |
#6 | |
haole kama'a-ina
Advance Auto, AutoZone, Pep Boys, Auto Barn, AutoPartsWarehouse typically $9.99 |
#7 | |
haole kama'a-ina
#8 |
Regardless of what the service notes recommend, I'll change my filter with every oil change. The extra $10 every 6000 miles or so is hardly a deterrent and the filter access on this vehicle is the easiest I've ever seen. Nicely done.
Joe |
#9 |
what do you guys use to remove/install oil filter? Did you buy oil filter wrench driver from your dealer? Does it fit M-110 filter as well?
#10 |
User-approved
Outstanding report Mr. Jock! I've also noticed that when using a M1 filter, the oil appears to stay cleaner for longer than a stock filter.
#11 |
Anyone use Amsoil oil filters. They are supposed to be coming out with a reuseable dry air filter too.
#12 |
Registered User
Are these Mobil 1 Oil Filters available in Canada?
#13 | |
Irvine, CA
#14 |
Registered User
This interesting comparison of DIY oil filters has been on the internet for a long time. For all the Frams sold, it's a wonder that there are not more failures.
http://minimopar.knizefamily.net/oilfilterstudy.html Check the part about the mobil 1 crimp failures as a possible weakness. |
#15 |
I agree that Mobil 1 is better than Honda, but Mobil1 filter is almost twice as expensive as Honda oil filter (I got some on ebay for $5.15 each). Given short oil change interval of 4-5K miles, it is not necessary to buy more expensive oil filter. I'd say $5 purolator or Honda is sufficient. One thing when you go 10K miles, then you need mobil1 oil filter
#16 |
Ukrainian RDX
2007 Acura RDX |
737 Jock, what about K&N HP-1010 ? It's approx $10 at amazon.com, but is it 3 times better?
#17 | |
Location: Home in Vancouver, BC, Canada, but currently working in MA
Exactly... if it's good enough for Honda, then it should be fine to use in accordance with the recommended oil change interval. Use what is recommended... Like gasoline, use 91 not 87 or 89 octane. Oil, use synthetic oil that is recommended for use in the RDX, and it should be fine... you could use Motul or Blue Purple, but I doubt it would make a detectable significant difference if you stick to the MID change intervals. |
#18 | |
hates the winter
I have only used a Mobil 1 filter once on my TL, and it showed no problems. I noticed with Honda motor oil, and filter after 3k the oil was pretty dirty. I used nothing but Honda oil, and filters on my previous 94 Integra LS automatic and it had no issues, and the oil stayed relativly clean for the 3k interval. With todays engines, and advanced oil and filters it pays to use the quality stuff. Especially if you own, and plan on keeping your car for some time. Lease, and 4 year trade in's would be fine with dealership oil changes according to the service manual. Nice write up, and comparison |
#19 |
Running Wix oil filters in my RDX now, they are of good quality (much better then oem) and priced ok too (I get em for 6.79 a filter from my local amsoil dealer) also use Amsoil ASL 5w30 in my prelude but use Pennzoil Platinum 5w30 in the RDX
RDX: PP 5w30 & Wix Filter Prelude: Amsoil ASL 5w30 & Honda s2000 filter So far no problems, once im out of the s2k filters i will try out amsoil eao's and push my oci to 10k (right now its at 8k) and this is KM's not miles. |
#20 | |
hates the winter
#21 | |
I have 2001 CLS and use Mobil 1 oil filter and Mobil 1 EP oil. I go 10K/1year between oil changes, usually its one 1 year because I only put about 7-8K miles a year. RDX is a different story, I can not use Amsoil or Mobil1 EP oils, you have to use regular Mobil1. Secondly, turbo engine does require more frequent oil changes. And third, if you want to keep your warranty, you better follow OEM intervals. As far as filters goes, you can't tell by oil color if anything is wrong. There is no question Mobil1 oil filter is better, but my point is that its not needed when oil change intervals are 3-4K miles. It won't hurt, but not worth spending $5 extra. |
#22 |
anyone done a comparison between the Purolator PUREONE filter compared to the Mobil 1? I have read that the PureONE is also a very sturdy filter as well.
#23 |
bobin
About Amsoil yes you can use Amsoil in the RDX. amsoil 0-30 is aproved by Honda to use in all Honda and Acura produtces and there oil filter also. EAo-13 or the next best oil filter to use is a Wix.
#24 |
Registered User
good info. Did not realize that the Honda filter was built by Fram. I will be using either a Mobil 1 or a K&N alternative from no on. Fram oil filters are junk.
Current Cars: 2008 Acrura RDX, Tech Package, Nighthawk Black/Ebony 2007 Mazda CX-7 Touring, Copper Red/Tan Old Cars: 2006 Mazdaspeed 6, GT, Platinum/Black 2003 Mazda 6s, Lapis Blue/Black |
#25 | |
Registered User
#26 |
Registered User
...... I found the K&N HP-1010 filter out on Amazon for $10, no shipping. Picked up 3. Assuming things are the same as when I had my first Mazda 6 which also used the same K&N part number the Mobil 1 and K&N were both great durable non-paper filters but the K&N has a higher flow capacity/rate. At any rate, I'd be willing to bet that my dealer is charging me a shade if anything less than $10 for the Honda filter at changes, can't put my hands on the bill from my first oil change. For the small, if any difference in price it is worth it to me to know I am using the best filter I can and makes me more comfortable with the 6k change intervals. The stock filter is no more than a low end Fram filter with Honda paint on the canister and probably should never be used more than 3-4k IMHO.
#27 |
Boy, 737 Jock really does good work. I'll ride his plane anytime.
#28 |
Does anyone have any comments on Puralator PureOne filter?
http://www.purolatorautofilters.net/...ilfilters.aspx Its not as good as Mobil1, but some people believe its the same or better quality than Honda, and you can get it for like $5. They claim to be 99% efficent in filtering.
2001 Acura 3.2 CL Type S Spoiler No mods! |
#29 |
It's been a while since I've strayed from OEM, but in my Mustang days, Purolator was one of the few decent brands. Most other brands are just rebadged frams.
It basically came down to OEM, Mobil1, K&N, Purolator and Wix. |
#30 |
I always use the recommended filter as long as the vehicle is under warranty. Why take any chances with a non-recommended filter?
2010 RDX Tech Basque Red Pearl/Taupe |
#31 |
Registered User
Basically anything but Fram. Might as well be a WalMart store brand filter...
#32 |
Registered User
Just becasue it is not an OEM part doesn't mean it is not reccomended and it won't have any effect on your warranty. The point is if you can do better than OEM for the same or in my dealer's case less cost and make it more comfortably to the 6k oil change interval, why wouldn't you? I wouldn't trust that factory filter beyond 3-4k. The filter media on the OP's factory filter looks horrible. To each their own but just because it isn't the Honda part doesn't mean it isn't "reccomended". Its better than OEM....
#33 |
I think this thread needs to be updated because the Honda oil filter used in this comparison is the Fram made one ending in "A02". There is another OEM Honda filter made by FILTECH ending in "A01" that is much better made all around. The only problem is that most Honda & Acura dealership only carry the FRAM made "A02" with the occasional shipment of "A01" filters. The last time a local Acura dealer carried the Filtech made filter, I purchased 15 at $5 a piece.
#34 | |
Rocky Mtn Nighthawk Black
2005 Acura TLMy Garage |
Dude could be wrong stating that the A01 is no longer being made, but I know they are very hard to come by. Good call buying 15 at a time. |
#35 | |
Sporty X type
'08 PMM/ Taupe, Tinted frt's, Clear Bra on hood, on mirrors & lower rear splash area! Have to get ZAINOed ASAP! |
#36 |
Yeah that's probably the route I am going to take from here. I think I'll try to find them in bulk somewhere since they will work on my Honda Fit as well. Got a couple more A02's left to use up in the mean-time. Thanks for the heads-up on the AutoZone price!
#37 |
$10 IMO is way too much to spend on a oil filter. There are very good alternatives to the Honda filter for $5 to $6 (Purolator PureOne or Bosch *also made by Filtech*)
#38 | |
Sporty X type
#39 |
Registered User
what information is available on the flow and filtration abilities of the oem and m1 filters. I think this is just as important as actual build quality.
#40 |
In my autozone the bastards jack up the price to $12 for Mobil1 filter.
| Tags |
| acura, buy, cx7, engine, filter, fram, honda, install, m1110, mazda, mdx, mobil, mobile, oil, review, synthetic, wrench |
| Thread Tools | |
