Steering wheel tilt issue:
I have posted about the steering wheel tilt before but never really got a resolution. So I feel like it has a slight tilt to the right. I took the car in for a checkup and the dealership said alignment is fine and it's not an issue..so I noticed that the whole steering wheel panel has a slight tilt to the right. I am not sure if you can see it in this picture. I know I am being anal about this but please let me know what you guys think of this.
Take a look at this picture...you maybe able to see what I am talking about. Slightly higher on left than right
So? What is the problem. Does it drive well, really, if you look at every piece of the car you will find some not perfect fits. Nothing is perfect. Look out the window and see how nice the world looks!
DealsAllTheWay (01-02-2014)
They can fix that for you with an alignment. Because you didn't deal with it within the first 30 days of ownership, it will be on your dime.
Personally I think you're making a mountain out of a mole hill.
It drives fine..no shaking or anything but that tilt just bothers me...
I did take it in for an alignment check and they said it's fine..they said all alignment is electronic now and they gave me a printout which shows it being okay
DealsAllTheWay...I am not sure I can see what you are talking about in the picture. Are you referring to the cluster assembly being a bit shifted to the right?
As others have said, in the whole scheme of things, its nothing to be concerned about but I am like you, little details like this would annoy me too. Now for the record, the alignment can still be good but have your steering wheel a little off. Seeing a printout of your alignment states that you (toe/camber) is OK and your tires won't wear out in an uneven fashion but you could still have your steering tilted a bit (ask the folks owning a Q50 (little joke...sorry couldn't resist).
As hand-filer stated, if you want to go through this, you will likely have to pay out of your pocket but if that bothers you that much, and I know it would for me, then I'd say its money well invested
btw, what do you mean about the Infiniti Q50? Is steering wheel tilt a big problem there?
^^ I did look at the picture and its hard to gauge (no pun intended) since the picture cuts off at the right hand side of the speedometer. I can sorta of see what you are saying but its a little inconclusive for me.
As far as the Q50, yes, some people were stating having the steering turned by a full quarter and the car still going straight. They are having issues with the "steer by wire" technology....
I can see what the OP is speaking of; it is the trim piece that is behind the steering wheel but in front of the gauge cluster. I have noticed the same thing in my 2014 that I received in mid-December.
It has nothing to do with the steering alignment, just how the trim and underlying pieces are installed.
My 2014 has the same issue. And I've seen it on other RDXs as well. It's disappointing because it's right in front of you all the time. But you get over it after having the car for a while. My steering wheel is straight, it's just the assembly between the wheel and dashboard/instrument cluster that is twisted several degrees clockwise.
Unfortunately I dont remember if this was always like this, or if it happened later.
rockyboy
12-06-2022 02:29 PM
EvilVirus
12-10-2015 07:38 PM
